6.0 Cab Bolts
PVXCummins
PA
Going to be pulling the cab in the coming weeks for head gaskets, injectors, etc. Good chance I will have to cut the heads off the bolts and lift the cab. Where can I get new cab bolts? Did a Google search but no concrete results. Anyone have parts numbers for them or are they strictly a Ford Factory part?
Thanks.
dEmOnpwrstrk
Why take the cab off. Go to YouTube and search 6.0 head gaskets, cab on!!
Sent from my SAMSUNG-SM-G891A using Tapatalk
dEmOnpwrstrk
All they did is take drivers engine mount off and Jack passenger side up to get to the bolts and hoist head off
dEmOnpwrstrk
Search 2006 ford f350 6.0l head gaskets, there's a video taking them off and putting em back on with cab on
05wh250
hendersonville, nc
I've got two that have regular bolts with lock nuts. Used the rest of the factory hardware, just had to cut the neck with the threads off the bottom piece.
dEmOnpwrstrk
To each their own, I would waste the time pulling the cab
imelmo
It only takes a couple hours to pull the cab. And if you're "fluffy" like me it makes things much easier.
PVXCummins
PA
Very true. I don't mind the little bit of extra work to have some space to work on the 6.0. Plus ill be pulling the 6.0 anyway. Want to really check it over and i may possibility be replacing the oil pan. (Showing some signs of flaking)
We had the cab off my friend's 6.4 this weekend in a few hours with only 2 jacks and an engine crane. Some redneck ingenuity at its finest. :evil
PVXCummins
PA
The cage nuts spin...
This ^^^^. Went through that yanking the 6.4 cab. Spun 2 of the cage nuts said fook it and cut the heads off. And i don't really trust myself with a torch around the rubber body bushings :lookaround:
dEmOnpwrstrk
I just try to do my homework before doing a job....that said, I've pulled heads and replaced, did blue spring and banjo update, 5" exhaust....all with cab on and prolly wouldn't have left cab on if I hadn't seen the video on it
PVXCummins
PA
And back to our regularly scheduled program and original question....... Where can I course new cab bolts and nuts?
sunrise ford in the vendor section. post in their thread.
jake74
Just goffing around you can have the cab up in 3 hours. Worst part is getting that heavy ass back seat out to access rear bolts. I could see where it might be a pain if the truck has been in the rust belt it's whole life. Cab up makes it so nice and it's much easier on the old back lol.
webb06
Seneca, MO
We never have any trouble
with 6.0 cab bolts. 6.4 is a different story.
Take the rear seat out and pull the carpet back to access the bolts under the rear passengers feet. A good impact will pull them right out.
