6.0 Gods... Please Convince Me!
KPSquared
Wetaskiwin, AB, CAN
Hey guys,
So, I'm a die hard 7.3 guy as is the rest of my family. My cousin just found a SMOKIN deal on a 2005 F250 CCSB. Low miles, never any problems. Have the full dealer history. Still under factory warranty. (For another month or so).
All I really know about the 6.0 is what I've read in the media and what I've "heard" online. Lawsuits, failures, piece of garbage etc.
So, I know there are a ton of guys that run them and love them. What would I need to fix the day we bring this truck home? What are the weak points and can they be strengthened to build a reliable motor?
The only repairs on warranty have been 3 injectors in the last little while. Its completely stock. 72,000 miles. Beautiful shape.
I don't have a ton of time to research this one so if you guys could help a fellow army brat out, that would be great! Thanks!
ADub
Bellevue, WA
My step dad's 04 6.0 has been great. I would go for it if the price is right. Delete the egr, add a coolant filter and don't look back. I wouldn't hesitate to pick one up.
SIX_OHH
A six liter.....is the sex. New oil cooler egr delete some studs oem gaskets a douggie fresh coolant filter.
Theres 2 types of six liters. 1 can be fixed one can be burned. @ 72k if the oasis is clean then ita a type one. Buy it up and youll forget what a 7.3 was.
SIX_OHH
Report of all the dealer work done. If you give vivian at quick tricks your vin number and ask nicly she will give you one. Post it up here when you get it.
SIX_OHH
Just noticed this is in the 6.4 section :D Mods if you could...
san antonio,tx
oasis is the like the ford version of a car fax.like stated above delete the egr,new oil cooler,and studs.there good trucks once you fix there issues.
SIX_OHH
Shes on the nation. Youll need to PM here. And yes it even works on canadian trucks if its a ferd :eek:
KPSquared
Wetaskiwin, AB, CAN
We talked to our friend that's the parts manager at Ford and he looked up the truck. He never used the word "Oasis" but he said it was any repairs that Ford had done to it.
All the work has been done here at our local dealership.
It's hard 'cause of all the 6.0 stories. I told him to buy it and plan to spend a couple grand getting the EGR and all the rest done.
So, just to confirm... I need these things to make a reliable truck...
http://shop.strictlydiesel.com/store.php/products/EGR_60L_Cooler_Delete
http://www.dieselsite.com/2003-200760lcoolantfiltrationsystem-preservethelifeofyourwaterpump.aspx
Or maybe just this? - http://shop.strictlydiesel.com/store.php/products/60L_MasterKit
Any idea why 3 injectors would have failed in 72,000 miles? That doesn't seem normal.
SIX_OHH
Sinister EGR Delete & Studs FTW
Truck will be pretty much bulletproof at that point
Negative!
Thats all it had was dropped 3 injectors? Anyway to post the report?
SIX_OHH
You should know thats not gonna fix all the problems a 6.0 could have.
ZacPSD60
Spring, TX
Well of course there's other problems that can happen, but the EGR delete and studs are some of the best preventative measures you can take.
SIX_OHH
Then lets not say it will be bulletproof. That's a little misleading.
constantfix
NJ
You are splitting hairs
you should be much better off once the studs and egr delete are in place.
Anything can go wrong on anything at anytime
