6.0 IC swap help.
Jomax
Arizona
Everything's out and ready to put back in, as I start putting the Diesel site kit, I come to find out both sides of the intercooler have the same diameter. Both ends need a tapered boot. So the straight boot won't work......Anyone ever see a 6.0 IC that has both sides the same?? Thanks
Sent from my iPhone using
TapTalk
2000 Black DRW F-350
Gauges, DP tuner, ported housing, T-500:evil:, JW VB, 5in turbo back, hutch/harpoon mod, 6.0 IC, tru cool tranny cooler, etc
Jomax
Arizona
Nvm found out its a 7.3 intercooler with plastic ends.
TapTalk
OSCS
Houston, TX
TapTalk
looks like you got screwed then..
Jomax
Arizona
No, honest mistake, getting it swapped for a 6.0 tomorrow.
TapTalk
Jomax
Arizona
Curious as to why you were putting in a 6.0 IC anyway?
EGT's.. even if it lowers it 50degrees it's worth it. In AZ EVERY bit counts..
TapTalk
co04cobra
WV
ohh. What kind of egts are you seeing? Honestly no way I would trade an aluminum end take for a plastic one. When/if the plastic cracks you will have high egts.
CSIPSD
Bend, OR
While I am no fan of the 6.0 IC swap, the plastic end tanks are not to worry... I see 45psi regularly, 54psi max once. Still there and together.
Jomax
Arizona
1350 on 4mile 6-7% grades in 115degrees. Needed new intercooler boots anyways. Paid 100bux for the 6.0 IC. I can sell my intercooler worst comes to worst for 50bux. I'm out 50 bucks, which IMO isn't bad and I'm changing a clogged radiator anyway, I was right there. Damn even if it lowers EGT by 25 degrees I'm happy. For the ends being plastic, least Of my worries, your radiator is still leak free isn't it? It has plastic ends..
TapTalk
CSIPSD
Bend, OR
TapTalk
Really?
Come on man, use your head...
Coolant runs at 15psi... your boost can run much more then that.
Jomax
Arizona
I wasnt talking about boost, I was a talking about how plastic can last...
TapTalk
co04cobra
WV
Didnt mean to start an argument over the whole plastic thing. Yes I have replaced several cracked plastic radiators and ICs. Your not out much money so go for the 6.0 IC. I was commenting to say I wouldnt spend a lot of money on the 6.0 IC as an upgrade. JMO.
Groomzybanshee
St Joe mo
TapTalk
Your still not getting it... He is talking about the boost blowing the ic apart. Nothing similar to the radiator.
Jomax
Arizona
I'll never make enough boost to blow a 6.0 IC apart. I get it btw..
TapTalk
TARM
Here is how I see it. The Op understands or at least after these threads should fully about the +/- and performance expectations of installing a 6.0 IC in place of a 7.3 IC. Its what he wants to do to his truck.
Jomax
Arizona
Thanks TARM.
TapTalk
Jomax
Arizona
If you want to lower egts get a 38r.
That'll be coming as well. Along with 160/100% AC injectors.
TapTalk
