Ok here it goes. 2006 truck new hpop and ipr starts good hot or cold no smoke 55 psi fuel pressure at idle and 45 psi at wot. Truck starts to die out above half throttle or 3800 psi hpo it acts like it is getting air in the hpop. But the desired psi drop first then the actual drops, if you dont pump the peddle the truck will die then it takes 30 sec to restart but when it starts it runs fine. This truck is bone stock other than a egr delete. Checking lpo tommorow the factory gage doesnt move when it starts to act up.
