Bustedknuckles
- Joined
- Aug 15, 2011
- Messages
- 1,503
- Reaction score
- 1
I have a 03 6.0 that I'm diagnosing a crank no start issue on. I have proper ICP, fuel pressure, and FICM voltage. However I am getting no ficm sync and a cam sensor code. My research shows that the cam sensor code can be caused by a extended crank so I'm not too bothered by that however i did swap the cam sensor and clean the mounting location and checked cam and crank signal at the PCM. I have signal from both at the PCM connector but I cannot find a spec or diagram of what the signal should actually look like. A guy who has been a tech for over 20 years said they looked good to him but that doesn't really say anything. What is odd is if I give it a tiny bit of ether it fires up and runs like a top. Any suggestions???
