6.0 performance parts
Petro
Lincoln Nebraska
What kind of power will these make roughly?, when paired with the right charger. Should be enough fuel for 8 or 900 correct?
Extended Power
I had a set of 285/100's and they come in right under 800 rwhp.
I also blew one of my hpo lines off on that dyno run at around 3000 rpm.
The graph was a wicked steep climb before the line blew off, and I'm sure it was gonna be a mid 800hp+ run on a Borg 369 over a GT 5594.
They will need a dual hpop setup to fully utilize them to their full potential, unless you want an engine that falls flat on its face at upper rpm.
I switched to 330/150 hybrids, and wish I never ph ucked with them...the 285/100's were the best daily driver/performance injector I have ever ran.
Petro
Lincoln Nebraska
Are they that oil hungry that even a modified single pump wouldn't hold full ICP?
slc dzl
Riverton, Utah
Bump
$1200 plus shipping on 285/100 injectors
Also have a used aeromotive a1000 and filter base setup $350
New Borg s467.7 83 .90ar $1000
