6.0 Underhood Pics
NoSlow6.0
Muscle Shoals, AL
Let's see some twin turbo's and twin HPOP's if you got em. If not lets see some highly modded 6.0 underhood pics or just whatever you got.
strokin6L
Springville NY
here's some of mine...pretty clean for a build date of july '03 and only 76k miles.
NoSlow6.0
Muscle Shoals, AL
Where did you get the caps for your degas bottle and other fuel caps. Also I see your running a dual electric fan setup. I always heard they wouldn't flow enough for these 6.0's. Also is it a custom piece you made or does somebody make one one for the 6.0's?
NoSlow6.0
Muscle Shoals, AL
Did you notice any performance gains from the electric fans? Cooler temps, increased hp? Did you have to modify anything to make it work or did everything line up and wire up without modifications?
strokin6L
Springville NY
Just gotta modify the inline trans filter bracket and use a couple of the brackets that came with it and modify them to bolt it to the radiator.
ford rules
Why did you get rid of them? Or are the still on there?
Also did you have any issues not running the factory shroud that bolts to the motor, id like to leave mine off not sure if i should though.
Very clean BTW are those No limit CAC pipes?
strokin6L
Springville NY
I sold them to pay for a turbo. They worked just fine. Temps stayed the same. I really wish I had them back. The cold side pipe is a no limit pipe the hot side is a factory pipe. I did however get a no limit hot side pipe but it didn't fit. The configuration of it wasn't the same as my factory pipe and it wouldn't work.
ford rules
Good to know!
So you don't have issues without the factory shroud on there?
