6.0L radiator in 7.3L?
Mayhemryder
Port Byron, IL
I have a question. I have a 2002 7.3 ford excursion and I noticed the reservoir was low so I added coolant only to find that it had a leak when full. I have a friend that put a aftermarket radiator in his 6.0 and his stock one is still good. Will the 6.0 radiator fit in the excursion? Ive read that the intercooler should fit but nothing on the radiator.
Mesa, AZ
You will have to do something about plugging the big hole in the bottom of the degas where it goes to the bottom of the radiator, as the 6.0 doesn't run that hose. The trans cooler lines will have to be modified, and depending on the year the radiator came out of it will either be a quick connect or a thread in. Seeing as the general cab configuration is the same, it should be damn close to fitting.
