webb06
Had a truck come in the shop a few weeks ago, customer said he heard a pop noise at a stoplight and then started idling rough. He first took it to ford dealer because they told him they would fix anything that happened to it, turns out they wanted nothing to do with it now. Figured it had a cracked piston considering the massive amount of blowby. It also had a banging/clanging noise. I pulled the cab and head off and found this....anyone seen this before? This is what it looked like after removing the head. The piston is missing, assuming it's in the oil pan, and cylinder wall is BEAT, so bad that all the coolant inside the block got drained out with the oil. In the pics you can see a few spots where there are holes in the cylinder walls.
