6.4 fuel bowl delete and unregulated return
Athens, IL
Got a new options coming down them pipe for everyone!
6.4 bowl delete and unregulated return kits.
These use a large high flow regulator that is actually rated for use with an a-1000 or fuelab prodigy pumps volume capability.
They also incorporate the fuel manifold into the regulator.
It's made to be a lower cost more "universal" setup.
You can run your cooler return with the factory fuel cooler or cut the return line and use the compression fitting to bypass it. All the returns tee into the return to tank line from the regulator.
Comes with braided pump feed line.
Also available with dual fueler lines add on. This will allow for the use of dual high pressure pumps.
The feed and return to the regulator are push lock hose and can be adapted to any style system depending on what you have. This part was left generic as there are so many different low pressure fuel systems available. It would be a waste of the customers money to include a bunch of fittings that may or may not be used for their application.
Just another option for people.
Pricing is $635 for the standard and $835 for dual pumps.
Lmk what you guys think!
Riverside
southern Oregon
Where's the fuel temp sensor new home?
Relocated, gone.
Sorry if it's a dumb question
Looks awesome!
I want.
devdiesel
Barrie, Ontario
couple pictures of this kit on my truck
