Breaking Habits
HX60 w/ 2.8 cover will make the most power.. Unfortunately competitiveness with a single charger 6.4 and drive ability wont come in the same equation.
In the end, your stock injectors and pump can make about 6-650rwhp, no matter what you do. More fuel than stock is required for 800+hp.
More wondering what the s467 fmw would make with say 60% nozzles and a dual pump set up, compared to a batmo s472.
Where you are at, is smoke a big problem on the street?
Where in Ontario are you, I'm from Trenton just west of Belleville. I've only pulled once at the end of last season and loved it in the local class. Waiting to pay the truck off before I get to "into" it.
Looks good man it wasnt bad pulling the motor from the front was it?
Got the engine tore down mostly today, found one of the pistons looked like its been getting a little toasty.
I see you have faith in your engine stand! I don't... I made a brace that holds the front of the engine from sagging too far. Maybe someday I'll buy an OTC
Sent while I probably should be doing something productive.
