6.4 Single build
CJH8907
the time has come to do away with the twin turbo set up and go to a single. going with 60% RCD nozzles and dragonfire pump. Trying to decide between a 466 double batmo or a 475 double batmo. Either way I need to figure out what size exhaust housing and turbine wheel I should run as I do not want to run a wastegate. Also going to be running RCD cam,springs, intake,uppipes, exhuast manifolds and tuning.
Any input would be apreciated!!!!!
Thanks
Jeff@Spartan
Georgia
Is that pump going to flow enough for 60% nozzles? I thought there was hard evidence that the Industrial pump couldn't maintain nozzles that big. I could be wrong though.
Maybe 60% nozzles are the biggest before rail pressure is effected?
Breaking Habits
Mapleton, Illinois
For some reason I thought you had 30% nozzles. Very cool then. Looks like he has the fuel side down then.
Sorry for the derail!
Just made the switch before Rudy's, love it.
OP, make sure you deal with me on your parts, we can go over different options you'll have.
Gonna run good!!
CJH8907
Jared, this is cody
Dusty should be getting a hold of you to get me prices on the turbo mount and the exhaust manifold prices
jdgleason
Fort Collins, CO
Depends on the pulsewidth.... The II pump will not maintain at full tilt with all out pulse width like a 310 tune or X race. Jared has pulsewidth pulled back a touch.
BOSS450
Concord, NC
Y'all dont know what y'all are talking about. The pumps are clearly advertised at 85% over. so they will hold pressure with atleast 85 sticks :flush:
White_monster
The great white north
I know you can. The guys with II pumps and airdogs can't. With dual pumps the duty cycle on the pumps is low compared to what the duty cycle in the II is. I'd like to try a bigger lift pump on pogs truck but time doesn't permit that to happen.
