6.4 Single build
pog
psa
i should be switching to dual pumps next year sometime so i will prob leave the ad as is.
CJH8907
Anyone any ideas on what size exhaust housing i need to run to keep a 1:1 ratio for back pressure, so I dont need to run a wastegate with the s475 double batmowheel
CJH8907
Thanks for the info. Just out of curiosity which one did you like better mostly going to be street driven with racing and pulling in the summer? Also did you just run the 83mm turbine or the 87mm?
extreme3807
Bucyrus, OH
I ran the 87mm...by far the. 90 was better... I couldn't make past 5 psi at the line with the 1.10. The 90 would light instantly, but I think you should also give the 1.0 a try. Thats what Craig runs.
CJH8907
Thats kind of what i was thinking. Is injector size an issue as I am going to be running 100%s(250hp)? I apprecaite the help
extreme3807
Bucyrus, OH
Same size injectors I had...shouldn't be an issue...They can be a bit smokey at times, nothing you can't control though. Have fun with it, I promise you wont be disappointed.
Mike@MPD
Pasadena,MD
I have the S472 Billet with 60s and II pump and it is a little laggy with a 1.10 housing on it, i just put up vids in the Non VGT vs VGT thread
CJH8907
Yeah that is little laggy I was thinking about the 1.00 housing. What size turbine wheel u run?
CJH8907
If you dont mind me asking what did you do for a downpipe. I am having problems trying to find a 5'' flange to go to a 4'' downpipe
