lubeowner
Took this off a truck. It does need the lines remade to your truck. It won't work with this truck as we are mounting the air to water cooler in front of the motor. $1800 Also have the fully built 5R with billet shafts and convertor that needs to find a new home, no cores on any of these. $4000
Here is the pump mounted on the truck right before it was removed.
Here is what you will get. Just what is in this pic.
