6.7 dual fuelers
Athens, IL
New dual fueler kits finally ready! We have spent way longer than we should have. But we are pretty confident that we nailed form, function, fitment and simplicity.
Here are some of the features and benefits:
One piece powder coated bracket.
Three bolt attachment to the engine.
All new hardware included.
No grinding to parts of engine to make fit.
Single feed stainless steel hpf line with rail adapter.
Pre-built fuel lines that work with oem top filter. Plug and play with factory style quick connects.
No more buying three filters and throwing one away like with other kits.
Re-uses factory dual sided belt or can be used with supplied single sided belt for trucks equipped with single sided belts factory.
Simple plug and play harness.
Very easy installation.
Made in the USA!!
We have been running this setup and have been very pleased so far with how everything works together one the truck. We have also been running it with a 10mm stroker pump running the factory filter with no flow issues and holding full rail with 100% nozzles. So needless to say the factory pump and filter setup so far flows a lot of fuel.
Here are some pics:
Pricing will start at
$1799 for kit w/o pump.
$2599 for kit w/ pump
We are doing a pre-order this week all new kits will be shipping starting Monday.
For pre order I am doing $1599/$2399 until Friday. You can only get it by going trough the website and when ordering put in the notes "PSA preorder" along with your screen name. You will pay the full price but when the order comes through it will refund $200 at order processing.
Hope you guys like what you see and feel free to ask any questions.
