campbellflage
Posted this up on the org, thought I'd post it here too just in case some are not members to both. Ran a couple hundred miles on it so far and its been great!
Big thanks to Marty's diesel for making the fuel line kit for me, top notch parts, and amazing customer service!
Setup is 1/2 draw to 8an to pump, from pump to post pump filter, to splitter block, to DI reg return (already installed in truck), 6an from regulater to 6.7 pump return side, 6an out of pump to old feed pick up tube in tank. Pump is powered by a relay activated by stock pump harness.
I have the wire harness for the water in fuel sensor, as soon as weather cooperates I am going to see if it will integrate with the stock warning light system (have a spare sensor and bottom of pump to try it out in).
