600hp was fun but boring. Going bigger!
vanderchevy18
Benton, Ks.
I need to send my turbo in to be repaired but it'll be a while before they can get to it. Does anybody have a cheap GT4202 turbo or GT42R center section I can either buy cheap or use for a little while?
vanderchevy18
Benton, Ks.
Yeah I hollered at him on FB. I can get mine fixed, but I need something till I can get it done. I thought about running something like an s480 as a single. Lol!
Powerstroke Cowboy
Montana
how about a 96mm??? you could get a 1.15 A/R T4 made up for it. Or smaller.....
When it lit you would be all grins... BUT would hate it at the same time!!!
vanderchevy18
Benton, Ks.
That's pretty big. I bet I'll be able to lite it. I have pretty extensive head porting and an upgraded cam. Plus a shot of n2o will get it going. Lol! Gimme some more info on it.
Powerstroke Cowboy
Montana
It has a 96/156 comp wheel not sure on the exhaust side right now.. I have those spes someplace. Right now it has a 1.27 T6 A/R exhaust housing.
I do not think it would fit in where you want it...
This is a full size coffee can...
and this is what it is...
I think you could spool it.... BUT might not fit it where it needs to go...
Powerstroke Cowboy
Montana
I lot bigger then the 400 frame... The S400 with race cover is 9.5 inches across. This one is about 11.5 about 12 in the biggest spot not to mention it is about 12 from the intake the the exhaust exit.. i was going to use as a atmo but did not fir where I wanted it. then tried it as a single but still did not fit.... and the OBS pickups have more room...
Powerstroke Cowboy
Montana
Yes it is a V-Band... Here are the specs..
Intake :5 inch
Outlet: 107mm outter diameter, 82.35 inner diameter
Compressor trim: .60 ar (anti- surge)
Compressor Wheel diameter: 74.80 /102.40 (big wheel)
Turbine wheel diameter : 75.35 / 81.70
Exhaust trim: 1.05ar
Turbine flange type: t4 flange ( twin scroll )
Downpipe flange type : 6 bolt type
Cooling type: oil cool only
Horsepower rating: 1000hp+
(wet float bearing)
vanderchevy18
Benton, Ks.
Yeah. I mean, I would love to get a little more off it since it is a Chinese turbo and I'll only use it for a little while...... But $500 is hard to beat.
