7.3 build
02POWERSTROKE7.3
Alexandria, IN
Just started tearing down the block I was planning on building to find a piston that had let go and cylinder wall has a whole in it from the rod. Would it be possible to sleeve it or should I find a new block?
Magnum PD
VA
The early obs front covers didn't have a drain back valve. I'd get a new block
02POWERSTROKE7.3
Alexandria, IN
Also in need of 1 forged rod if anyone has one, let me know. Going to talk to the machine shop this weekend and see what they have to say, also got another block im going to get.
02POWERSTROKE7.3
Alexandria, IN
Piston failed, bent rod, and rod rubbed a hole in the cylinder wall. Found another block to build. Going to need a good forged rod and 3 injector cores.
Chrisf97305
Salem Or
I would say if the rod just rubbed a hold in the cylinder, I would have the block checked for cracks and have it sleeved. There is nothing wrong with sleeving a engine if it is done right.
