ju015dd
OK guys. I just have the best luck in the world. After finally getting the new to me engine swapped over to my rig , I think I have destroyed it. Truck seemed to be running fine for a couof days. I had been watching the coolant level because I had to replace my radiator after I found a crack around the upper hose connection. Coolant kept disappearing out of the overflow tank so I would just add some more thinking I just had air in the system. Now truck never showed that it was running hot last night on trip home from a friends house. Egts were around 700 degrees and dummy gauge on dash showed normal. But it got to where I could smell truck was hot so I pulled over and shut it off. No coolant in overflow once again and when ever I tried removing cap enough to let air out coolant would shoot back in. Finally was able to add more coolant after about 20 min of waitin . Fired truck back up and made it home . Truck will not run now, so I drained the oil and had quit a bit of coolant come out of drain in pan then what looked to be decent oil. Also before I drained oil I tried starting truck one last time and had what looks like coolant pouring out of exhaust. I am so pissed at myself right now and don't know where to start......... Any help or guidance would be much appreciated.
