01 blue 7.3
I put in a fuel psi gauge and hooked it in on the fuel filter bowl, running about 65 psi all the time. Is that normal?
Most 7.3's running regulated return's are between 60-70 psi. So your GTG.
My OBS on a stock fuel system will run 70-100psi fuel pressure. The fuel bowl has been fully rebuilt, regulator isn't plugged up, my gauge and sending unit are good... I don't get it. I have thought about cutting a coil or two off the FPR spring to drop the pressure but my truck runs pretty darn good so I haven't messed with it.No reason to go over 60 to 70. I did the stiffer spring once. Truck ran worse at higher pressure.
If it works, don't fix it. Rule #1 in life.
