Thank you. I see them now. It's a banjo plug I would have to modify them to allow feed from both rear and side ports. Spendy suckers...
Well it's not that badly priced but it's a M12x1.5 banjo bolt adapter which many companies sell... They will not quite work for what I am trying to do anyways. I'm building a Mechanical/ Efuel setup. I'm leaving the mechanical fuel pump and adding a SD pump with its own feed on a pressure switch. I may just Y it outside the rail and run it all into the adapter. I will likely have to check valve both sides of the pumps anyhow.
