7.3 OBS Electric Fuel System Bowl ******
doctorsmack03
I did some research and assembled a very nice looking OBS electric fuel conversion. I didn't have the money to pay $1300 for the Driven Diesel kit so I took my rac car knowledge and made my own. Plus I like the look of black Fittings and Hose personally. It comes with everything needed...
(1) Frame Mount for Filters and Electric Fuel Pump
(1) Baldwin Fuel Water Seperator(7633) and Filter(1212) Set
(1) Bosch Super Duty Fuel Pump
(1) 30' of Eaton Push Loc 6an Fuel Hose and Black Fuel Fittings(only 20' Needed)
(2) 12" Sections of Stainless 3/8" Fuel Hardline Tube with Earl's Fittings
(4) 1/8" to 6an Fittings for Cylinder Heads
(1) Push on EFI Fitting to Attach to existing Hardline
(1) Freeze Plug for Factory Fuel Pump Hole
(1) Aeromotive Y Block with 6an Fittings Installed
(1) Aeromotive Fuel Pressure Regulator with 6an Fittings and Alternator Mount
(1) Driven Diesel Wiring Kit
(1) Driven Diesel Installation Instructions
I won't write out exactly how many Fittings are included, but according to my hours of research it is everything you need to get this done just like the Driven Diesel Kit. I mapped it out exactly and I have no doubt that everything is included. It is 6an or 3/8" the whole way through just like everyone else uses. The Stainless Hardlines will have to be bent to your specifications using a tubing bender or by hand if you'd like, but that is not a hard job honestly. I mounted the Frame Mount, Pump, Filters and wiring kit a month ago. I also assembled the Fuel Pressure Regulator and Y Block. Then my wife got sick and I need to sell the truck. So, sadly it will be listed shortly as well. But, for now I need to recoupe as much as possible to help pay some bills. Text me for fastest response. $850 shipped to the lower 48 and I accept PayPal as a gift unless you add 3%. I'm in Fayetteville, GA.
Thanks,
Vince Accardo
(310) 901-0562
