7.3 performance parts
Dalton,NH (The White Mountains)
i have a set of brand new alliant injectors that have been modified to a 315/200 with about 10k miles on them...these are not remans... asking 1850 plus a good working set of cores to stick back in my truck..
i have a brand new never put on the truck SRP 1.2..this is one of the last one built..this is a perfect pump to transform into a honey badger SR for 300 bucks at dyno proven,, asking 600 plus a good working 17* pump...
i also have a brand new never used 467 FMW turbo for sale..
67.66mm/2.66'' Compressor Inducer Dia.
3.60'' Compressor Wheel O.D.
74.29mm/2.92'' Turbine Exducer Dia.
83.47mm/3.29'' Turbine Wheel O.D.
1.10 Turbine A/R
T4 Twin Flow Turbine Inlet
full race cover with 5 inch air inlet and Straight Compressor Outlet asking 1250
brand new turbonetics T4 kit..all stainless steel up pipes air filter tube with filter,hot side IC pipe.. Y and a 4 inch down pipe..comes with all bolts mounts and oil feed lines...asking 1500...
driven diesel full fuel feed kit with a fuelab pump brand new never used has pump 5/8 pick up tube 5/8 fuel line and wire harness..asking 600..
call or text 603-991-2910 evenings only..no cell service where i work..
Fuel kit complete? Have part #?
it is a fuel feed kit..has the 5/8 pick up tube with fitting to come out the top of the tank into 5/8 hose going to your water separator filter then to the fuelab pump..1/2 hose from the pump to your fuel filter under the hood...the kit also has the wire harness and mounting bracket for the pump..ill try to get pictures tonight...
Sent you a pm
sent one back...
StandAlone
So this is the standard regulated return kit from driven diesel?
Could you PM me some pics/post them on here OR text them to me at 918-424-6622
no this is a fuel supply kit..it feeds the RR..are you the one that text me last night about this kit and the injectors and was going to make a deposit on them ??
