7.3 towing power
TyCorr
Yea. Just at low throttle input after 65mph its fine...55-65 if you are cruising if you hit a hill and try to hold speed it'll come up 100-200 deg. Didnt do it before the wheel.
rsater1
FLA
the KC TURBO is rebuild able.. unlike the 38r ..and has the billet wheel on it and has better numbers. less boost lag ..everything that the 38 r was lacking .the kc pretty much addressed ..been doing ;a
rsater1
FLA
the KC TURBO is rebuild able.. unlike the 38r ..and has the billet wheel on it and has better numbers. less boost lag ..everything that the 38 r was lacking .the kc pretty much addressed ..been doing ;A LITTLE RESEARCH ..LOL .BUTT they are still testing ..AND IF U LOOK ..IT IS CHEAPER ..IN THE RIGHT SPOT ..
Dmstrucks02
Pearland, TX
Who in here is crazy about billet wheels in 38r? Raise your hands!
I have one, my hand is down.
That wheel sucked azz on my truck too, it was an immediate difference when I put the stock wheel back. It was nice at WOT but this isn't a puller so...
it smokey pulling my rzr around on a 16' trailer
Just swapped back to the stock wheel. Much better bottom end power. Very noticeable power increase when towing.
On a side not, I have a WW2 for sale! Anyone???
Same results here, one of the only mods I regretted and went back on
PSD POWER007
Columbus, GA
The 6x6 wheel was superior in my 38r to the 11 blade billet wheel.
My brother in law put a new KC38r turbo in his excursion with FF 180/80's. That turbo is flat out awesome. He's got the 1.0 housing. It's better than my 38r ever was.
And I'm not hating on my 38r, it was a nice turbo.
TyCorr
What difference can you tell with a little a code and an 80% nozzle?
What's different about the kcr?
TyCorr
I believe since our trucks are setup similar we had similar results. Im gonna try some GH tunes with my 250/200s before I ditch it for the stocker.
Did you ever try the billet wheel with your 238/80s?
Dmstrucks02
Pearland, TX
No I didn't, still stock injectors
TyCorr
Got ya...i was gonna try it with 33s and stock suspension. I took the rear apart first. 3.5" pmf block and 4 leaf rear sd springs (3k lb rating), put the tires back on and its sitting level :doh: either my 6" lift settled a lot or this thing is gonna sit high af...
Dirtclod
Pilot Mtn. NC
I know in my near future I see a turbo. I'm definitely going with a t4 setup and hopefully stock injectors will hold up for a while. What turbo is recommended with stockers,4" dp,s&b,reg.return pre and post filters hd tranny upgrade? I'll probably either have a php hydra or infinity from dp when I get a new turbo. I don't know a lot about the belle turbos or hofsett. Any recommendation is appreciated
lincolnlocker
Central Michigan
Ive got metric shti tons of fuel its just not a good fit for me for some reason. I don't know if its the 35s and the 3.73 gears. It gets hot. I need to do some other stuff to it before I go back to the stocker. Hell i may try the billet version of the cast wheel. Mines the 11blade single plane wheel as well.
ahhh, whitey has 4.10s on near stock tires.. biggest i have ever ran on her where 285/75/16s
live life full throttle
TyCorr
Yea, that makes a huge difference. I like a bigger tire, especially on a 4 spd as it makes each gear longer.
I like the 6 spds but unless you keep it stock it makes no difference for me. I can run way over the speed limit at 2k rpm. Just need to address that hot spot. I had a tow tune through Bill@php thst was grwat but it was for stock fuel.
Dmstrucks02
Pearland, TX
I'm on X codes and stock block out back, I think I want to go back up with it
TyCorr
Well, i put a 3 1/2", 2.5° taper block on my back end and the 4 leaf rear spring pack (whatever code it is) and it sits level with the front end of my old setup. Which is a 2000 model 6" skyjacker leaf spring lift. Im not super happy at the moment. I guess I should have got a 2" ***kin block. Here i was worried about the 35s and im gonna be airing them sonsabitshes out still.
TyCorr
Hell these are my 37x13.5s...dont mind the rusty frame...id ground all the paint and overloads off. Then it got rained on.
