7.3 Turbos, Borg Warner S480, S475, Holset HX-50
NRHX2009
Elizabethville, PA
1. 99.5-03 7.3L F-Series Stock rebuild with Wicked Wheel. $575
2. 99.5-03 7.3L Van Turbo for F-Series. 1.15 A/R Non wastegated housing with homemade downpipe adapter and Wicked wheel. $600
3. Rebuilt Early 99 E-series Van turbo. $550
4. Stock Rebuilt 99.5-03 F-Series turbo. Stock comp wheel. $500
5. Bullseye Power/ Borg Warner S480 with 91x81mm turbine wheel with T6 1.25 A/R housing $ 875
6. Borg Warner S475, Bullseye Power Race Cover compressor housing. BRAND NEW CHRA (new bearing housing, comp wheel, turbine wheel) Used comp housing and turbine housing. T6 1.32 A/R 96x88 turbine wheel $825
7. Holset HX-50 66mm comp. inducer, 86x77mm turbine wheel. 19cm T4i exhaust housing. Fits H2E mount. $600
8. Holset Reman HC5A Turbo PN: 3594085, Compressor wheel is 3.3" inducer x 5" exducer, Compressor discharge is a 3.5" slip on connection,Turbine Wheel is 5" inducer and 3.74" exducer (E-trim), Turbine Housing is a 40cm T6 Divided $1800
PM, Text, or Call for pics and more details.
717- nine one nine, 7423
Powerstroke Cowboy
Montana
Which turbo would spool well with 250/200's as a big single? Shooting for 500-600hp?
As they sit the HX50 would spool the best...
The S475 would work if you would put a lot smaller exhaust housing on it.. Like a 1.00 A/R Or even the .90 A/R housing on it.. That S475 has a BIG turbine wheel so I would say a .90A/R with a gate of course..
I wish this would have come up before i bought my turbo's. I would jump on atleast two of them...
NRHX2009
Elizabethville, PA
For sure the HX50
young7.3
Southern Indiana
I'm a retard when it comes to turbos,so help me out.what mount does it require and how universal is that mount when it comes to mounting other turbos to it?
Powerstroke Cowboy
Montana
It would take a T4i mount for the SD 99-03 range pickups.. Jake@Irate diesel sell's I nice kit.. His kit will come with everything needed. IF you tell him you want everything to mount your _______turbo...
As far universal. It is not to universal the T4i is not a very commen foot option.. BUT with a little modding you can make a T4 foot fit the T4i mount.
NRHX2009
Elizabethville, PA
BRAND NEW IN BOX
COMP TURBO CT-43 / CT-5 Hybrid Turbo
76mm Billet Compressor Wheel
Triple Ceramic Ball Bearing
Oil Cooled Only
82mm 10 blade straight cut turbine wheel
Lightweight Billet Aluminum Bearing Housing
T4 0.90A/R Turbine housing
4" V band Turbine housing discharge
4" compressor inlet
3" slip on compressor outlet
This turbo is comparable to a Garrett GTX-4202R turbo at a lower price! The GTX4202R is $2600
This turbo has CT43 housings but wheels from a Larger CT-5 series turbo.
This Custom Turbo was just over 3K New and is STILL NEW!
Turbo has not been installed or run in any way.
$2500 COST 3K
PM, E-mail, Text or call 717-919-7423 or [email protected]
NRHX2009
Elizabethville, PA
Thats about it for now. I'll keep adding to the list as they come and go. I am personally looking for an S366 T4 1.00 A/R with 83x75mm turbine wheel is anyone has one!
