Black 02
What is the scoop?
No response from Joey. Pretty frustrating.
I've been driving with the stock pump and it's been running pretty well. Very subtle surge at mid-rpm (could be trial tunes), but otherwise pretty good.
I still have the heavy smoke on startup and also the hazing at idle. There's also the random miss at idle when warmed up. Since it did this in the previous engine, I've been wondering if there is something not quite right with the injectors.
I've been told by several that some of that can be worn or poor tolerances in my injectors. I decided to pull them out yesterday to send in for analysis. Pulled the #6 injector and heard a subtle chugging noise. Look over and see my degas bottle coolant level going down. FML.
So, I'm guessing when I pulled the injector, an injector cup moved. I don't know why else the coolant level would start dropping. I pressurized the coolant system, but it won't hold pressure and it starts filling the cylinder with coolant. I can't removed the cup by hand, but I can't think of any other reason why this would happen.
I swear it could be raining pu$$y and I'd get hit by a giant dick.
