7.3L stalling
Huero350
I need some help guys I have a 2002 f3507.3L and it stalls on me randomly while I’m on the hwy it just shuts off out of the blue i wait for about 10-15 min . Crank it and it starts right up ,I replaced camshaft position sensor and icp also but I’m still stalling I’m getting code P1200 anybody know what I can do ?
Arisley
Arlington, Texas
That's good. Did you check the connector on the CPS, make sure it is in good shape.
Also, like Magnum said, check oil level and get it on a scanner so you can see HPO.
Huero350
Ok I’ll do so and keep you guys posted
gwunter
Logansport, IN
Did it start doing it after it rained or any type of moisture contact?
Huero350
No it didn’t it just started out of the blue
Huero350
Ok just wanted to update you guys I checked all the things you guys suggested and it ended up being the IPR valve so far after I’ve changed it haven’t had any problems yet !!
