Paul@CP_Trucks
Hey guys we have brought a new product on board direct from a PSA/PSN Board member. We have had several problems with the 7.3L Thermostat housings leaking after a water pump job.
Here is the fix for that.
:redspotdance:
The first 25 of these will receive $5 off of your purchase. :ford:
Retail Price: $40
DISCOUNT PRICE: $35
/IMG]Here is the fix for that.
:redspotdance:
The Ford thermostat housing mounting flange is one of two sources for coolant leaks at the thermostat housing to water pump interface. The square cut o-ring that Ford uses is the other source. The Thermostat Housing Flange Reinforcing Ring, (THFR Ring) effectively stiffens the weak thermostat housing flange eliminating any chance of bending. No need to replace your existing bent housing as the THFR Ring will straighten it. The only reason to replace the housing is for excessive corrosion. Stiffening the thermostat housing flange also allows the use of an improved o-ring. The THFR Ring, along with this new style o-ring, effectively eliminates the thermostat housing coolant leaks that plague the 7.3L Powerstroke engine.
Kit contents: 1 - Installation Instructions
1 - THFR Ring
1 - O-ring
3 - Bolts
3 - Washers
The THFR Ring in this kit is made of 304 stainless steel and will not corrode.
Retail Price: $40
DISCOUNT PRICE: $35
