#7 injector problems
6.4sleeper
Alright guys, I'm new to the 6.4. I bought it about two months ago and deleted everything and have Spartan tunes. I use the truck as my daily driver back and forth to work and a little fun on the weekends. I'm getting two codes. P0207 injector circuit/ open cylinder 7 and P1000 OBD systems readiness test not complete. It runs very rough and has no power whatsoever. I plan on pulling the valve cover and checking my wiring harness for power and resistance of the the injector itself. If you guys have any ideas or seen this problem is surely appreciate the help!
crashidy
The p1000 never goes away i don't think. At least i don't recall it ever going away on my edge. However it sounds like you need to check your injector.
Sent from my GT-I9100M using Tapatalk 2
6.4sleeper
I tore it apart and tested the harness and injector itself. The solenoid on the injector was shot. So the injector is bad. And now you mention it I have talked to many guys about the P1000 and it will most likely never go away.
