71mm
smokinstroker
Texas
I guess it really depends where you are. Altitude can be that deciding factor for sure!
Sea level always puts a bigger smile on your face!
johnp115
Southern MD/Charlotte NC
getstroked27
Friendship, MD
agreed. i currently live at 120 feet or so. its so cherry. i lived in the snowy mountain range in south eastern wyoming, town was at 8200 feet.... no bueno there
Jeff@Spartan
Georgia
There are also very few accounts of people breaking 12.3 on stock fuel with a 71-71mm and no nitrous.
I was also basing it off elevation in Maryland which is ~3,000ft.
3,000 feet? Maybe up on the tallest peaks.
Truck weight has a lot to do with it too. It's possible to get a crew can down to 7600 lbs or so if you're willing to go that far with it. I got mine down to 7620 without messing with the interior.
johnp115
Maybe west part of Maryland.. But the majority of it, like eastern shore, southern md and mid md is all surrounded by the bay and rivers and less than 140
travisH3
Cincinnati, Ohio
I'll try lowering tire pressure and see what it will do. i believe i was at like 55psi. I already have traction bars. the mickey thompson atzp3 are also a more aggressive all terrain so hopefully they will bite okay.
ya-drop your pressures waaay down. also, it may help to launch off rpm not boost. 1750 rpm seems to work well.
ONEFASTSTROKER
Southern Maryland
100hp is what I seen some companies clam. I think a tune would have to add around 300hp if 6.4 is rated 350 at the crank to make 570ish at the wheels with a tune.
B585Ford
WV
I saw a 47 horsepower increase.
594 uncorrected to 641 uncorrected. Same dyno.
Yours is one of the only same dyno before and after numbers I have seen, but based on a lot of peoples accounts, that seems like a pretty good average increase (maybe a few more than "normal" but your truck was a bit of freak anyways).
