94.5 severe overheating issue, need advice
Mad Max
in, out and all around the matrix you live in
got my 94.5 7.3 p-stroke back today from the shop, drove it 8 miles and the coolant gauge was red lining doing 65 down the road, water isnt coming out the top, bottom, sides anywhere, it has pressure.
the t-stat and water pump are brand new and t-stat is installed right, could this be a fan clutch or radiator issue( took 30 minutes to drain it tonight) i'm honestly out of ideas.... anyone got one?
psdguy95
Effingham, IL
Make sure your radiator fins are free of dirt and of anything that will block air flow. Is your belt on correctly? I've seen people put them on the wrong way making the waterpump not flow correctly.
kadeninabnitt
Martinsville, IN
thats what i did just ran it seemed to go away with that one having the cap on the rad may run it for a little bit with the cap off might help
Pstroke96
Connecticut
not to be a d1ck.. but are you relying on the dash gauge? i would hate to see you do all that work just to find out your gauge is lying to you cause they arent exactly the best, my truck used to be in the red within about 5 minutes of running and i didnt even have heat yet. but if you already know for sure it is overheating, continue on
Mad Max
i am relying on it, and i'm pretty sure its not too far off, after i drove the truck home from my buddy's place i saw it was on red, stopped, turned off the truck, opened the radiator cap and about a gallon and a half of coolant spewed everywhere, shouldnt have done that after 8 miles, as slow as i was going, but thats just my opinion, if i'm wrong i'd like to know
and youre not being a d!ck man, if you were i would have no issue callin you out on it haha
LA_Stroker
Pasadena, CA
Hi all, new to the Army but not to PowerStroke Forums. Intros done? Cool.
Does the current T-Stat have the small check ball in it? If not I always recommend drilling a small hole (like 3/32"-5/64") in the body of the T-Stat before install and like Speeddemon already said lifting the front of the truck pushes the air in the heads to the front of the block for easy evacuation.
Pstroke96
Connecticut
the truck does not have to be over heating to blow coolant off when you pop the cap hot. the system is pressurized and when you release the pressure the coolant will push some out even if it is functioning properly.
i would go to the parts store and get a cheap numerical gauge and plumb it in. you can use the existing sending location right on the top of the water pump. that way you can get an idea of where you are running. anything from 190 to 210 is a good temperature to be running at
