JSchuricht
For local pickup only in Austin, TX
95 E4OD 4x4 and transfer case with 122k on it. It's stock, shifted perfect when I pulled it to put the ZF6 in. $500 for the trans, $600 with the transfer case, $150 for the transfer case by itself. Both are currently separated so you will need a new gasket to put them together. The transfer case is off a F250 and I can throw in the drive shaft if you want it.
Also for local pickup, NP273 with a automatic input shaft off my 00. Shift motor included and was working when I pulled it off my 00 at 199k to install a NP271. $300
I take cash, BTC or LTC and can deliver if your not too far away.
