99 7.3 F350 exhaust smell low boost.
ja_cain
Sensor unplugged, valve pulled open.... It was stuck.
Couldn't blindly unhook the actuator arm though 😒
Armed Gunman
Good stuff. I'm glad you figured out. My boss always says, "the data will tell you what to do next". You gotta love those stupid EBP actuators. I'm deleting mine first chance I get. Please throw up a screen shot of your monitoring program when you get a chance.
hoosierstroker
Ran it through the do it yourself car wash and only washed the motor..... I couldn't even get the arm off but I pulled it open I think it was stuck shut.
Pull the arm out is open.... Correct?
Actually rolled a little coal driving afterwards.....
Gonna do the delete on thursday
Armed Gunman
ja_cain
Are those the numbers after forcing the valve to the open position? If so, then you need to clean the tube and make sure the sensor reads atmospheric pressure (or close to it) at idle. Does the back pressure respond to throttle under load input. If not, then something is clogged or broken. I think you can read back pressure when the key is in run position and engine is off in Torque Pro. Should read atmospheric pressure there too.
lincolnlocker
Central Michigan
the rod is spring loaded and pulls on the arm to keep the valve open. when the pcm calls to close the valve, oil pressure pushes againt the back off the rod forcing it out to close the valve.
id say you ebps is clogged and reading off.. id start there.
live life full throttle
ja_cain
I feel like I should have asked my previous question from the beginning. Regardless of whether the valve is sticking, ebp should still fluctuate once the motor is loaded. If it's not moving then sensor is broke or tube is plugged with residual pressure that not being bled off. I bet that bad boy is slam full of crud.
ja_cain
I bet that thing is slam full of gunk. It's a no brainer to go ahead and clean that bad boy especially if his motor has been air starved for a significant amount of time.
Arisley
Arlington, Texas
That ABS sensor will not mess with boost. Mine was plugged solid for over a year, even before I unplugged the sensor, I could bounce of the peg of my 35 lb gauge, swapped it for a 60 lb gauge and could almost bury it.
lincolnlocker
Central Michigan
of course not. why would a sensor in the wheelbearing mess with boost levels?
now if someone tunes off of the ebps is could...
Oops EBP sensor.
And yes, I understand that, I had a tuner fill up a chip for me once. It ran like A$$ until the EOT got to 175º.
ja_cain
Was it plugged and measuring significantly above atmospheric pressure like his is? I would think that it would effect fuel delivery some if it always measured high. That's how I would make it work if I designed the system, but maybe it doesn't carry much weight with regard to fueling. Just sounds stupid to me.
