AB to AD Injectors
dzldoctor
Can you swap AD injectors in place of an early 99 with AB injectors without much issue? Have a buddy trying to be cheap I have a set of low mile AD and his early 99 needs injectors. I read the AB flow 130cc? Both split shot. Should be ok?
Justin@DP-Tuner
As 04stroker said, they will work just fine. The truck may be a little smokier without the correct AD tuning, but the truck will run fine.
