been having a issue with my brakes lately on my 2011 f350 srw 4wd, when i hit the pedal it would pull hard to the left and it would release itself and then pull hard again, so i went to change my brake pads and they were wore so i went ahead and changed those and my caliper on each side was leaking around the rubber boot so i changed those as well. while i was in there i noticed my wheel bearing was grinding so i changed it a week or 2 ago. the other day i pulled all my abs fuses and the issue has gone away so its either the module or the solenoids/pump. my issue isnt the abs i can live without the fuses in it but i cant live without a trailer brake controller. anyway to bypass the abs but also have my trailer brakes to work? ive already played with all the fuses and all 3 have to be in it for the brake controller to work, or am i stuck having to buy a abs module/pump?
