ABS wiring diagram
wjamesm
Bellefonte pa.
Does anybody have a wiring diagram for a 2011 f-350 . I have a right front wheel speed sensor code that triggers the ABS light and advance track warning and hill descent warning . I replace the wheel bearing and sensor wire to no avail . So I have read about people having chaffed wires breaking and loose plug connections causing these problems . I want to check the wires for continuity at the plug by the E-Brake to see if it's a wiring issue before I take it to a dealer to check the ABS unit for a problem .
