AD or AC Injectors with T4
glovemeister
How do you guys think a set of AD or AC injectors would run with a 364.5 with a 74/80 wheel, and a 1.0 housing?
MossBack
UTAH
Not laggy?
With the right tuning no. I run Jelibuilt tunes on my 1997. It runs better than my stocker ever did with same injectors. Under 1800 Rpm i don't really spool. from 2100-2800 she comes alive. Again im a much larger turbo with little larger nozzle than you are considering and I can spool to 34 PSI no sweat. I set my truck up so I can go 300/200's once I have a built trans. for now she is a fun truck. Ive towed 14k with it and i run it pretty hard with no issues besides my Overdrive slip when i push the truck past 90mph
Bmcgarvie
Port Angeles,WA
I'd run the .91 housing. I have 180/30 injectors and it's very responsive. But for smaller injectors I doubt I would like the 1.0 housing.
PSD POWER007
Columbus, GA
I don’t see why anyone would really need the 1.0 housing unless you are running larger injectors. With 180/80’s I maintain a 1:1 boost/back pressure ratio all the way up to 43psi. And EGT’s are not a worry. I pulled my 11,000 lb cargo trailer up Monteagle (5 mile 6% grade) at 75mph and never broke 1150* and maintained around 30psi.
alexander.leeiii
Been running a t-4 S 362 stock injectors 40 hp Ficm tune and I had my normal tune set to shift points where I drive because I drive a lot between 45-50 so now it goes on over drive at 45 works out good
TMCCOY
Utah
Don't run the 1.0 housing, it's laggy on the street and the .91 does fine for EGT. A 363 may be a better choice.
