Ae on 2001 7.3
Ok guys so I was trying to use my auto enginuity on my 2001 7.3 today and for some reason on the enhanced power train option there is nothing showing up under the actuation tab any ideas why? The tab worked in all other functions I have the enhanced ford package?
2001 ecsb 7.3, gtp38r, blank pedestal, ccv mod, reg. return, ad2 pump, gh tunes om a hydra, bts built 4r100,and more
2012 yfz450 bunch of stuff
Nevermind I guess they don't work for our 7.3s after a little more googling I found that out lol.
Apaarently it only works for 6.0s and I think newer just not for 7.3s and I'm only talkin about the actuation tab everything was working fine apperntly not for 7.3s.
mandkole
Northwest
^^ Yes, the enhanced package for diesel does work for all 7.3s as far as I know. IIRC, its been awhile but I had to do something specific on the software download to make it work. Then, the VIN showed up as a 2000 7.3 when I loaded it.
It's been working fine it won't read vin. If I enter it manually I have used all other functions pulls codes no problem data logs special functions just was looking to shut off 1 injector at a time as you can with 6.0s but can't do that with our 7.3s.
That function would be under the actuation tab along with a few other operations but it is blank.
Arisley
Arlington, Texas
Nope, cannot shut off a single injector with a 7.3. The IDM does not allow it. It takes a break out box. However, if it won't connect to the PCM, you have another problem.
It won't read the vin it's a 2001 but if I enter manually it will work fine
