Aeroforce A-Pillar
d7es3l
Colorado
Is it possible to make the aeroforce gauge power cable from the OBDII reach the a-pillar comfortably? I kind of laid it out & it just barely reaches the bottom pod in the 3-gauge pillar. I am wondering if I need to get a new spot for it... Where is everyone else putting there's?? Thank you.
Bobby@cp
I've had it in the top spot in my obs and its now been in the top spot on my sd for about a year now.
d7es3l
Colorado
I think my first problem might be that the OBDII is facing opposite the driver side. This isn't normal is it?
oneton
fla
I want to say the cable is about 6ft long.mines above the mirror with some slack in cable
d7es3l
Colorado
My cable comes out the right side facing door, I took my OBD off the hangers it's on & turned it around. I will see if I can reach it now
d7es3l
Colorado
yeah its the right port. It wouldnt plug in if it wasnt. He has a 95. They face down. 96 97 point straight out. Or at least 97 does
I contacted Aeroforce & they are sending me a longer cable! Hopefully this one works. Those guys are great!
mandkole
Northwest
if your cable points out of the plug to the pass side, are you sure that the plug has not been messed with? Both my 94 and another 95 both bring the gauge cord out of the plug pointed to the drivers side.
Why it took Ferd until the SD to get it under the column is beyond me...:shrug:
