Air Bags with Lifted Trucks
jbair14
Colorado
Pirogue
I have Firestone Riderite air bags on my '13, recently I ordered a 4.5" lift from Trevor at PMF with a welded side plate on the 5.5" traction block to bolt my Air bag to. I haven't received the lift yet but hopefully it should work.
NotStock
Tucson, AZ
Something like this?
Str8Ugly
Odessa Tx
trevor have anything that will work with a turn over ball? my draw tite goose neck plates are right there where that bag is, also the handle to pull the pin is on the drivers side frame
WHY NOT
Carlyle IL
This is what I have except with OUO traction blocks.
jcain
I just use blocks that have side tangs on them. Works fine with lift and b&w
NotStock
Tucson, AZ
I tried to make clearance for that in our setup. Do you have a pic of your setup? I could give a better recommendation.
