Air bags
marc1982443
I'm looking for the over leaf spring system that will work with the b&w turnover ball system. Does anyone know if there is one available?
mwdguy
Edmonton, AB
I dont believe the over leaf works with turn over ball because the brackets mount where the hitch does. I have the over leafs on my truck but no hitch
powerstroke22
Long Island, NY
Here's mine not to bad if you want to do it just have to make top bracket.
Are you dead set on bags? I just put in firestone work rite overloads and they mount in the stock bump stop location and doesn't require air. They go down and contact the stock block on the ear where the stock bump stops would hit.
marc1982443
My buddy got the timbern 8600 pounds springs. I like the idea of the bags. I'm already putting in an air compressor and tank.
Buck1
Winchester, IN
Air Lift makes a bag kit for B and W hitches that goes in place of factory bump stops. I've had good luck with them.
Sent from my SAMSUNG-SGH-I537 using Tapatalk
Horns07
new mexico
I have these also. They work great and they install wasn't too bad to do.
