99powerstroke7.3
My truck having hard time starting, slow long cranking nd a lil puff of white smoke. Im 1000 miles off my oil change so I decided to check it again to see air bubbles on the dipstick. Any ideas
Don't jump right on that conclusion. That could be it. Check easy stuff first. Check the HPOP res. level before starting the truck. It should be close to the top. There is an Allen head screw on the top of the reservoir, pull it out and stick a small screw driver, hunk of coat hanger, etc. down the hole to check the level.
Could be glow plugs if it is cool. Could be voltage. Could be a lot of things.
Do you have a way to scan for codes and monitor the PCM?
Very true Ty.
