Allison MT654 beef-up?
OldschoolPSD
Central VA
Does anyone know of a shop that builds medium duty Allisons?
I just picked up a p-pumped IH 4800 4x4 to replace my F-450 for gooseneck duty. I'd like to juice it up around 5-600hp but I know the Allison is the weak link. Obviously a stick would be the easy way out, but I like the auto's for pushing snow and I know there's no way I could row a 9 speed or an 8LL fast enough to take full advantage of the power.
I know Kyle Dunkle was putting 1200hp or so through a 545 Allison in his drag truck but I havent seen him around the truck shows in the last 2 years or so.
OldschoolPSD
Central VA
It's an NGD DT466. The truck is a '95. It's one of the last mechanical DT's so its got the roller cam, better flowing head, ect.
Plan is fire rings, valve springs, slap a 12mm Cummins P-pump on it an S480.
OldschoolPSD
Central VA
New Generation Diesel. Most call it the DT466C but the real name is NGD
Stock DT pump is 10mm. Cummins pump is 12mm. Swap the cams in the pumps and its a nice little upgrade.
OldschoolPSD
Central VA
Oops try this one. Anyone want a boom lift body?
OldschoolPSD
Central VA
It's gonna be a slow build. We are slammed with work right now but I wanted to get the truck purchased before the end of the year for tax reasons. It will probably be next spring before I can work on it. Got my hands on some 16.00r20s from my natty guard unit so I might try and get those on there soon though
