big johnson
how hard would it be to put a built allison in a 02 7.3? just a thought. or would i be better off to go with building up the stock trans?
But the Allison 1000 series do have larger hard components comparatively correct? Would sure be nice to have a couple extra gears as well comapred to the 4r100
They do make a flexplate / bell housing adapter to mate a Allison to a 7.3
Tuning limited? Even with a stand alone controller? There seems to be some built up one handling as good bit more than 400HP; a lot more. If we are talking stock a 4r100 can not even hold that without work. Figure if you were going to use a stand alone controller regardless. Both built up my GUESS would be even cost but you then need to add in the adapters etc so more cost. But you are also gaining gears. On the street could be very nice. After all we are talking about a 10 yr old tranny design here
You have to get the adapter for the transfer case, modify/move cross member, modify drive shaft length and yes you will have to check the clearance of the trans to the tunnel. The allison is quite a bit bigger than the 4r100. You might have to run a 2" body lift. Not sure if it will fit without it or not
