Amp cooling box (pic heavy)
WHirsch1
Millington, TN
Figured I would throw this up. I built a amp cooling box for the truck that is mounted behind the back seat. So here it is.
Used some 12v 5in computer fans. A little overkill but they were free.
Cut doors on either side to access wires and adj. without pulling the whole box.
Covered the inside with some sound Deadening to try to take some of the fan noise out. And put a thermostat on the fans so they wouldn't be on all the time.
WHirsch1
Millington, TN
Thanks. The fans come on at 88 and shut off at 86. The thermostat is spliced into the remote wire and then comes out to the fans.
