Another 7.3 no start..
littleredstroker
where the antelope play
Pull the valve cover and check for oil pouring out around the base of the injector. Bad oring would be my guess.
Possible. Not ruling that out, but these of rings have maybe 5k miles on them , 15k on the injectors themselves. I guess that's as probable as a crapped adrenaline with 20k
TyCorr
No scangauge? Is it building icp? The poormans gauge? Listen. The truck will wing over effortlessly and as hpo comes up the cranking will slow as the starter labors to crank an hpop full of oil. Id crack a line or head fitting BEFORE I started checking injectors.
littleredstroker
yes, same number comes up on the scangauge, 65xxx psi. duty cycle climbs up to 90%in just a few seconds just like before. It never changes tone while cranking cranks fast and easy never slows down, never smokes. It just isn't building hpo pressure. It honestly sounds exactly like its out of oil, which is not the case...
littleredstroker
I guess I never noticed the LPO pressure... i will have to check that tonight when i get off work. LPOPs usually go out like this ? ive always had good oil pressure.
edit: It doesn't make sense for resivior to be full tho..
wchsnowremoval
It may have the oil pressure and the fuel to work but no communication from Idm to command injects to fire. Just a thought.
2000wa250
Only time I've ever seen those kind of numbers on my scan gauge (psi wise) were with an unplugged ICP sensor. Have you tried unplugging the sensor and cranking it so the pcm defaults and calls for the injectors to fire?
My thinking here is your ICP sensor **** the bed, and is sending out a voltage the pcm/scan gauge doesn't know how to interpret. No signal from ICP sensor = no command to fire. If res is staying full there's two really only three options.... hpo leak (external would be obvious, internal is limited to o rings), pump is shot (oil is never leaving the res) or ICP is bad/pcm isn't commanding sticks to fire. Need to verify that pcm is sending the fire signal. Pull a vc and have someone crank while you listen. Should hear solenoids clicking. Or unplug ICP sensor and see if that changes anything.
Depending on what you find easier, you can either pull the hpop or pull sticks to test for the first two options. Personally only time I've had a no start because of o rings the res would not stay full if truck was warm and sat for a decent amount of time.
To test hpop pull it out, cover the intake hole with your finger (small hole to the 4-5 o'clock of the drive) and turn the pump over. If pump is dead, there will be zero suction. This is really obvious if you throw a pair of latex gloves on when you test it and cover the hole with your thumb.
Fwiw my money is on no command to fire injectors.
littleredstroker
Once again, if that was the case wouldn't the injectors not buzz with a buzz test if the signal wasn't coming through...
Maybe I missed it but were you getting smoke? Are you getting any fuel to the injectors?
Zero fuel. No smoke.
wchsnowremoval
I would try to swap in a known good idm. Correct me if I'm wrong but I believe the buzz test is performed through a different part of the Idm then when it's commanded to "run".The icp pressure would bleed off it the Idm where commanding the injectors on while cranking.
2000wa250
No. I mean that the pcm deliberately isn't sending the signal...
