So my T Case is stuck engaged.
Last year it wouldnt engage so i replaced the shift motor and the relays. Worked fine up till now.
(Disclaimer)
I did have to rotate the shift motor about 1/8 turn to get it on the shaft. It would not go on with the shaft in any position. So i put the t case in disengaged position and adjusted the motor accordingly.
Symptoms
T case engaged
No 4x4 light
Hubs would not unlock
Blower does not default to defrost vent.
I replaced the relays again to no avail. Ended up manually locking then unlocking the hubs, tapped on them with a hammer and they unlocked. Idk if it was the hammer or the locking/unlocking manually that unlocked the hubs tho.
Im guessing the shift motor is shot but idk why my hubs wouldnt open using the ESOF.
Anyone have an idea before i take this bish in. I dont have a place to wrench on it untill another few weeks.
(Disclaimer)
Symptoms
T case engaged
No 4x4 light
