Another minni maxx towing question
Drwoodchopper
Utah elevation 5800ft.
Just got it installed tonight and when I purchased it I didn't realize the pyro readings would be worthless. Not sure why? My Edge seemed to read them accurately?? So I am towing tomorrow and will be grossing about 18k or so. Do I dare run it in the tow mode? Or should I leave it stock until I can get the block off plate and sensor installed? I have been towing by the pyro for so many years with my 7.3 I am nervous to tow without an accurate reading.
Thanks
drunk on diesel
I'm not sure where pyro 1 is located or how they have it scaled for DPF present, but for removed, it's scaled high to fool the ECM
Will@Rudy'sDiesel
Burlington, NC
If you have the correct plates for the EGT Probe, take the sensor out of your DPF/CAT.
It should be the first sensor in the exhaust. Screw it into the plates, and plug it into the factory harness and wa-la!!! You are now able to monitor you EGTs.
