another no start!
89 Stroker
Southern Cali
there is smoke sometimes , i just drove the thing and it sat for 2 minutes then went out to try again , what the tach movement? this thing runs great when it starts , does not die or anything , but at first start up like sitting overnight i get the usuall smoke , it gts to oerating temps and i shut it off , not even a minute goes by i try again and it just cranks
Bugman
Gypsum, Co
If it is covered in oil it just may be it.
Here are the part numbers from the Nation
IPR Connector with 12" Pigtail
(International) 2501107C1
IPR O-Ring Kit (for when IPR valve replacement is not required)
(Ford) F6TZ-9C977-AN (F6TZ-9C977-AA?)
(International) 1825806C92 (1825806C91?)
IPR Injection Pressure Regulator
(Ford) F4TZ-9C968-C (engine serial no. 187099 & before or pump no. 255C92)
Part number F4TZ9C968C was superceded by part number 2C3Z9C968BA
(Ford) F81Z-9C968-AA (engine serial no. 187100 & up or pump no. 247C91)
(International) 1824982C91 (engine serial no. 187099 & before or pump no. 255C92)
(International) 1833798C91 (All Years ???) latest part number
(Motorcraft) CM-5013
89 Stroker
Southern Cali
im at a loss here , went to ford and got the o rings , still does the same thing , not even a minute after shutting off it just cranks and cranks wanting to start , iv read symptoms of a bad ipr are rough idle and driving , this thing idles perfect , drives perfect , perfect throttle response and everything , something is still up with my electrical system as when under heavy throttle the battery gauge comes on and flickers , and the gauge is at half even when running and operating temps
StrokerGuy86
Murfreesboro TN
sounds like you may hae a drain on your battery or a ground issue if nothng else checks out just read a guy wt the same problem. But every truck is its own beast.
StrokerGuy86
Murfreesboro TN
He ended up doing sensors and new cables and all. He put new batteries in it before all this and then he said went and had them check and they were bad. Got new ones and starts every time. Don't know it if will fix your problem by can't hurt to get them checked. I always go back to basics my dad always told me gotta have fuel fire air and compression. Diesels are a little more of a paid . I found a link the other day let me see if I can find it again. Might help
89 Stroker
Southern Cali
iv read those and my truck really does none , only thing i can think of is possible ipr , it runs fine , does not lope or cut out or loss in power , all fuses checked out even unhooked the fuel bowl heater , or at-least the test light lights up on all fuses under the hood , anyway to test the black relays in the fuse box under the hood?
89 Stroker
Southern Cali
Can you get a scanner on it at all to see what numbers you're getting while cranking?
not sure if the super-chips scanner does that , does not throw any codes either besides the ebpv and such , dont have a tach in my truck so cant tell if the cps or not
79jasper
skiatook, Oklahoma
Have you tried unplugging the icp during a hot start?
Oil level in engine? Smell like anything but oil?
Baker42
New Mexico
Is there oil in the lifter valley or on the bellhousing? If so call diesel o-rings http:www.dieselorings.com> or check out riff raff. Replace icp o-rings,HPOP lines orings ipr O-rings.
Couple of years ago I had a no hot start and it was my HPOP lines. Gave me an excuse to put an adrenaline on the truck. I orderd the pump and when I went to install it the o-rings for the lines were chewed up. Live and learn.
89 Stroker
Southern Cali
well , charged my batteries over night , put them in and unhooked the hot wire from the starter relay over to the gpr , before when it was all hooked up i would get small sparks on the batteries when hooking up , now i didnt get any and it fires right up , any ideas?
