Anyone recognize this plug?
JohnT24
OXFORD CT.
I was snooping around under the dash looking for an accessory wire. (Keyed power)
And found this plug unoccupied
(it was clipped into an empty plastic keeper)
Does anyone know what it would be used for in another model/ option etc?
White/purple tracer is keyed power.
Just curious.
Sent from my iPhone using Tapatalk Pro
JohnT24
OXFORD CT.
If anyone has a link to a wiring diagram...
I am using this wire to trigger my E-fuel pump relay ....
So I'd like to know if there is a fuse associated with it.
Bugman
Gypsum, Co
No idea, it could be for a AIC.
As for power to a E fuel relay most just use the fuel heater wire under the hood since you also need to change out your filter housing.
Sent from my SM-A426U using Tapatalk
JohnT24
OXFORD CT.
That wire
Which happens to be red with green tracer I believe
It's also tied into the glow plug relay.
been there done that.
If you cut the wire and run your relay directly off of it,
You will not have no glow plug action.
I suppose you could split off that wire and still use it
But but I choose not to do that
I want a dedicated power lead.
JohnT24
OXFORD CT.
This wire under the dash is working just fine.
But I still would like to find out what the original intent was for that plug.
That way if the fuse blows I will know where to look.
Bugman
Gypsum, Co
I didn't say to cut the wire to the fuel heater but to use it. Yes, it ties into the hot wire for the glow plug relay but it is a easy key on power source and since you do away with the filter housing why not use it?
